¿La batería del Leaf E-plus es realmente LG Chem?
Iniciado por Fernando M, Enero 13, 2019, 11:54:56 PM
Batería fabricada por AESC con tecnología LG Chem.
2015, Nissan IDS de 60 kWh:
http://foroev.com/index.php?topic=3754.0
https://insideevs.com/nissan-ids-concept-future-nissan-leaf-drag-report/
"Mr. Schmitt explains, "While I was working the Renault/Nissan Alliance dinner on Tueday night, a leading Alliance engineer told me that the battery will be built "by us and LG Chem." Then, two alarmed handlers stopped the discussion.
This would indicate that the tie-up between LG Chem and Nissan has been finalized, and as expected both company's will be producing the same battery for the LEAF.
Our own suspicions since word of a joint battery agreement between the two companies surfaced, has been that LG Chem will fill production needs for Nissan outside of the United States and Japan for the next generation, long range LEAF."
2019, Leaf E-Plus de 62 kWh::
"The battery pack cells are made by LG and are still passively cooled, which has been an issue in the past. However, Doi says Nissan has learned a lot in the almost decade of the LEAF and now believes that, even with the tighter pack, batteries will keep their capacity longer than ever. Nissan offers a 8 years/160,000 km (whichever occurs first) warranty on the battery"
Correction: 2 Nissan executives strangely stated on the record and recorded that the batteries were LG. However, after a report saying NESC in fact was still making the batteries and packs came out, I double-checked and it is in fact NESC making the batteries.
https://electrek.co/2019/01/08/nissan-leaf-plus-62kwh/
Sospechoso al menos.
Batería del E-Plus, 288 celdas:
Batería IDS, 288 celdas:
No entiendo muy bien. Quieres decir que la bateria es AESC pero con la tecnologia de LG Chem??!!!  ???
Tecnologia cedida, pagada o robada??
Tecnología LG Chem a medias.
Es decir, módulos LG montados a lo AESC como hace 8 años.
