Megane eléctrico
Iniciado por Fernando M, Julio 12, 2012, 10:33:30 PM
Continental demonstrated its electric vehicle expertise by converting an ordinary conventional car into an electric vehicle (EV) prototype.
The company integrated around 40 of its EV components in the vehicle, including the motor, battery, power electronics, novel displays and controls, all the peripheral devices for propulsion and charging, and special Conti.eContact tires.
Most of these components are ready to go into production or are already being mass produced.
"All the know-how that has flowed from all five of our divisions demonstrates that Continental has the technologies and systems expertise for electric cars. This is particularly significant as electrification of cars is becoming more and more of a reality," said Continental CEO Dr. Elmar Degenhart.
The prototype is fully functional and has already logged over 10,000 kilometers (6,200 miles), a testament to the work of Continental's Systems & Technology Automotive department and in-house Engineering Services which built the prototype in a little over six months.
At the heart of the Continental prototype is an externally excited synchronous motor, the likes of which Renault has already fitted in thousands of its electric cars. The motor generates 70 kilowatts and maximum torque of 226 Newton meters, propelling the prototype from zero to 100 kilometers per hour in 11.9 seconds.
Continental has been for now the only manufacturer to mass produce an externally excited synchronous motor in the automotive industry.
The motor has several major advantages compared to permanently excited electric motors. Externally excited motors make for high efficiency throughout all ranges of operation. Particularly at high rpm, regulation of the excitation current yields lower mutual inductance. This technical feature also serves to protect the motor. Yet another advantage is that no expensive rare earth metals are needed for the magnets.
The electric motor is coupled to an integrated single-gear transmission and a differential that includes a mechanical parking lock, power electronics and an electric vehicle controller. The second-generation power electronics stem from a flexible modular system.
Even with the built-in DC/DC converter, the unit is some 30 percent smaller than the first generation, making it one of the most compact components on the market. Automotive designers thus gain valuable space while reducing total vehicle weight and extending the range. The central control unit – the brain of an electric vehicle - is derived from a mass-produced engine control unit. It not only controls the drive mechanism but also manages temperature, energy and recharging.
Power comes from a lithium-ion battery. Including its built-in management system, safety electronics, the innovative crash sensor evSAT, and liquid cooling, the system weighs 154 kilograms, allowing installation in a sandwich floor without sacrificing any space. There was no change to the trunk space or to the flexibility of the interior on the concept car.
The battery pack has a nominal voltage of 355 volts and a capacity of 18 kilowatt hours which gives the car a maximum range of 150 kilometers.
An on-board charger by Continental, on the verge of mass production, recharges the battery. The charger features modular design and is scalable. It has been designed for electric cars and plug-in-hybrids – hybrid vehicles whose batteries can also be recharged from an outlet. The high capacity of 10 kilowatts means that it is possible to completely recharge the car in just over two and a half hours.
For Continental, the connected car of the future will be able to dispel fears about running out of electricity unexpectedly while on the road. Drivers will be able to consult a freely configurable instrument cluster to obtain information on the remaining range based on such data as energy flow, charge state, active radius and current traffic conditions. A 12.3-inch LCD screen, similar to the display on a tablet computer, will notify drivers at a glance of all pertinent parameters. Depending on the purpose and the operating status, drivers will be able to obtain trip and battery data, navigation tips, tips on saving energy, or even find the nearest recharging station. Developers have left a lot of room available for individual configuration of information requirements.
Another innovation in the electric demonstration car is its active accelerator pedal, the Accelerator Force Feedback Pedal (AFFP) by Continental. It is the world's first mass-produced active accelerator pedal. Its built-in actuator and completely programmable haptic feedback signals offer entirely new ways of helping drivers to travel as economically as possible. Depending on the driving program chosen, it will be possible to select a variable pressure point along the pedal in order to signal the most economical pedal position to the driver, for example. At the same time, it will be possible to increase pedal resistance in relation to the charge remaining in the battery in order to signal diminishing range and the need to drive more economically. Since such feedback can also help decrease fuel consumption on cars with internal combustion engines, and since the AFFP can serve as a warning signal for impending danger, its use is not just confined to electric vehicles.
The converted prototype is fitted with new Conti.eContact tires that the Hanover specialists developed especially for electric cars. Its unusual 195/55 R20 format and aerodynamic rims are not just there for looks. They exhibit 30 percent less resistance to rolling, which means considerably extended range. The new tires, which feature automatic monitoring of tire pressure, permit up to ten percent further kilometers.
Mainly responsible for the gain in distance is the unusual tire diameter. Deformation decreases when the tire approaches the contact patch, resulting in greatly diminished resistance to rolling. At the same time, the same load bearing is possible as with ordinary tires. In addition, Continental has formed the sidewalls so that less energy is lost when the tires deflect or top out. The sidewall dispenses with the usual edging and design elements, just like the very smooth and largely enclosed rims, in order to diminish wind resistance as much as possible.
The tread design features a combination of four longitudinal grooves, numerous sipes, an absence of transverse corrugations, and stiff tread ribs, all trimmed to provide lessened resistance to rolling and less tire noise. It was also possible to achieve precise handling characteristics and safe braking under wet conditions. The very low tire contour prevents excess travel by the belt elements and therefore lowers resistance to rolling and what's more, the new tire is lighter than previous designs.
The first thing one notices in the interior of the Continental test car is the upholstery covering the sporty seats. Designers availed themselves of the innovative material Acella Eco Natural by Benecke-Kaliko. Its green-blue color and stamp, reminiscent of a computer board, fit the electric car visually but the new material is especially environmentally compatible, easy on resources and skin-friendly. The material has roughly 40-percent renewable raw materials content and has, when compared to standard trim material, a 14 percent better life cycle assessment. It also satisfies the Oeko-Tex Standard 100 requirements.
Finally, engineers integrated the various electrical components into the car in such a way that they were able to save several yards of high-voltage wires and numerous special connectors compared to similar vehicles. That led to a significant cost advantage on the one hand, but also less weight and therefore, increased range.
Magnífica demostración tecnológica. Personalmente considero mucho mas adecuados los síncronos excitados que los de imanes permanentes para los coches eléctricos, en el texto pone claramente el porqué.
Esperanzadores años nos aguardan. Sigo manteniendo que para 2020 los coches eléctricos coparán la casi totalidad de las ventas.
Bomarang
#2
  Que guapo !!! Podrían hacer un Laguna Coupe eléctrico...hoy por hoy, es el único Renault que compraría por diseño...Saludos
karlosk2
Bipo, los motores tanto de nissan como de renault son sincronos por lo que tengo entendido, no???
muy buena autonomia para esa bateria, personalmente opino que la refrigeracion de la bateria tiene bastantes beneficios en estos momentos hasta se solucione la degradacion por el efecto de la temperatura, un aplauso para Continental.
saludos
Síncronos son todos, sí... En un coche no sería buena idea meter un asíncrono. La diferencia está en que los de imanes permanentes tienen siempre el mismo campo en el rotor, mientras que los de anillos rozantes permiten variar la excitación a voluntad, lo que permite optimizar mucho el rendimiento del motor. El problema... Eso, que los anillos rozan, aunque no es para tanto, no es comparable con el desgaste de las escobillas de un motor de colector. Los de imanes permanentes son más robustos en ese aspecto, pero también llevan elementos caros en sus imanes (neodimio, etc.) conocidos como "tierras raras" y que incrementan el coste.
Yo personalmente prefiero la versatilidad de uno excitado, tiene más ventajas que inconvenientes. Sobre todo en un coche eléctrico, que por simplicidad no lleva cambio de marchas, a pesar de tener que abarcar un rango enorme de rpm. Permite mejorar el rendimiento en bajos y en altos.
Por hacer un símil, digamos que los síncronos excitados son como los motores con distribución variable.
Puede que las ruedas Continental valgan para el ZOE, con llantas de 19" no de 20":
http://www.moteurnature.com/actu/2012/renault-megane-electrique-continental.php
"Enfin, les pneumatiques sont annoncés comme ayant une résistance au roulement 30 % plus faible qu'un pneumatique classique. Etonnant, mais les dimensions le sont aussi : 195/55 R 20, et ces pneumatiques seuls permettraient d'accroître l'autonomie de 10 %. La Renault Zoe sera la première à bénéficier de ces nouvelles gommes, sur des jantes de 19 pouces. "
